SLAs results (Offering commitment)
AB5
I would like to ask for your help. I cannot work out how reports regarding offering's SLA commitment works. I need to see results in HOMEPAGE - MY SERVICES SLAs and it doesn't show results.
When I register incident against particular service offering, SLA regarding such offering is lunched (for example P1 Resolution 1hr 24x7). For test purposes I am waiting until such SLA is breached (like 1000% breached). Then I am closing this incident and it didn't bring any updates on particular gauge. Please refer to attachment. It should present that sla was breached. I did lunch all scheduled jobs regaring SLA, but no effect. Can you please let me know how can I use this functionality?
I DONT GET IT 😞
AB
26 REPLIES 26
Mark_Didrikson
Go under Script Includes >> SLAResultSummarizer
Update line #34 to be:
if (gs.beginningOfDay(this.start) == gs.beginningOfYesterday()) {
It should currently be:
if (gs.beginningOfDay(this.start) == gs.beginningOfToday()) {
Thanks!
The answer here is very close to my question. Maybe you can advice me. How i can configure them. For example dates for may april march as following.How i can configure those ones
Nik Amy
Hello Adam,
Same problem is faced in my company. Its 100 % everywhere. Did you get the root cause of this issue.
I also found that the gauges on My Services - SLAs homepage were not updating for the Service Offerings. Everything showed 100% and green.
I found the KB article here about changing the script in the Calculate SLA Results job to look for more than just yesterday's updates.
This did fix my issue after I updated and re-ran the job.
Hi Chris,
currently i am working on my services sla page and facing the same issue on personal instance....and also i am not able to access the article.
Could you please mention what action exactly needs to take with with Calculate SLA result job.
