02-14-2022 05:46 AM
Hi ,
we have a catalog under which we have added Something is broken as category under it we have added Report an Issue (record producer which generates Incidents when submitted).
The issue is when a category is selected , sub category is not getting populated. from the self service view
but sub categories are getting displayed in Native UI and Service Portal.
Please Help how to populate the subcategories. ( previously they were populating but not now)
Multiple Versions
02-14-2022 08:53 AM
Hi, In the variable attributes field can you configure as ref_qual_elements=Type your category field name and try one more time. If not working can you share your clean screenshot.
Please mark as helpful/correct answer if helped.
Suresh.
02-14-2022 09:27 AM
If simple report then, you should go to Reports --> create New --> configure the things --> define the qualification as created this month and generate te report.
Parallelly, create another report for last month.
Please mark as helpful for further questions.
Suresh.
02-14-2022 09:29 AM
you are saying to create 2 reports in a single dashboard right?
02-14-2022 09:37 AM
Yes, you should create the 2 reports and club in one dashboard.
Suresh.
