SYS Is not in query ?
sukran
In Server side background script how to query glide record ... Sys Id is not ..
Below query is not working
var rec = incident.sys_id ( stored incident sysid records)
addQuery('sys_id , '!=', rec);
ANY IDEA
James Chun
Hi @sukran,
Use the following query instead:
addEncodedQuery('sys_idNOT IN'+rec);
I am assuming the 'rec' variable is an array which stores the sys_ids.
Cheers
11 REPLIES 11
Did you also debug exit.trigger_id, does it contain the value you would expect?
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
exit.trigger_id = returns sys id as expected
James Chun
Hi @sukran,
Cheers
Its works with mentioned code
var usrLoc=[];
addEncodedQuery("sys_idNOT IN"+usrLoc);
Passing the value to array ,then its looks good
Mark Roethof
It should be able to work. The other suggestions are fine to. Question is more, is the other content in your query valid, did you verify? For example "rec", is that valid? Did you debug?
What can you share.
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
