Trigger approval through workflow script to a group which is present in a custom table
1_DipikaD
I have a custom table called portfolio which contains a field approval group which refers to group table. Also i have a catalog item which has a variable (reference type) which refers to Portfolio table. So i want when i select any Portfolio record in the catalog variable approval should go to the particular group which is present in that record. There is a existing approval group activity in workflow through which multiple approvals are getting triggered . So from there i need to trigger the approval to the groups.
Please let me know if more info is needed.
Thank you
It would really help if you shared your script.
SAI VENKATESH
Hi @1_DipikaD
You can try the below script:
var portfolioSysId = current.variables.portfolio_variable_name;
var portfolioGR = new GlideRecord('portfolio');
if (portfolioGR.get(portfolioSysId)) {
    var approvalGroup = portfolioGR.approval_group;
    current.approval_group = approvalGroup;
Thanks and regards
Sai Venkatesh
No doesn't work  and not sure why you put current.approval_group = approvalGroup;
Hi @1_DipikaD
You can check the below Script:
answer=[];
answer.push(current.variables.variable_name);
I have tested in my PDI and it is working Fine.
Thanks and Regards
Sai Venkatesh
