UI page code is not working - need urgent help
ssunpreet55
Giga Explorer
<j:jelly trim="false" xmlns:j="jelly:core" xmlns:g="glide">
<style>
body {
    font-family: Arial, sans-serif;
    display: flex;
    justify-content: center;
    align-items: flex-start;
    height: 100vh;
    margin: 80px;
    padding: 80px;
    background-color: #F4F4F4;
.container {
    width: 700px;
    background: white;
    padding: 40px;
    border-radius: 8px;
    box-shadow: 0 0 15px rgba(0, 0, 0, 0.1);
    margin-top: 20px;
h2 {
    text-align: center;
    color: #333;
    font-size: 28px;
    margin-bottom: 30px;
form {
    display: flex;
    flex-direction: column;
label {
    font-weight: bold;
    display: block;
    margin: 15px 0 8px;
input, select {
    width: 100%;
    padding: 12px;
    margin-bottom: 20px;
    border: 1px solid #ccc;
    border-radius: 4px;
    box-sizing: border-box;
button.submit-btn {
    width: 100%;
    padding: 12px;
    background-color: #007BFF;
    color: white;
    border: none;
    border-radius: 4px;
    font-size: 18px;
    cursor: pointer;
    margin-top: 20px;
button.submit-btn:hover {
    background-color: #0056B3;
</style>
<script>
 function onSubmit() {
console.log("Submit button clicked!");
    var contractorSysId = document.getElementById("contractor_sys_id").value;
    var newManagerSysId = document.getElementById("new_manager_sys_id").value; //:white_check_mark: Capture sys_id
    console.log("Contractor ID:", contractorSysId);
    console.log("New Manager sys_id:", newManagerSysId);
    if (!newManagerSysId) {
        alert("Please select a valid new manager.");
    var ga = new GlideAjax('ChangeContractorManagerHandler');
    ga.addParam('sysparm_name', 'createRequest');
    ga.addParam('contractor', contractorSysId);
    ga.addParam('newManager', newManagerSysId); //:white_check_mark: Send sys_id instead of name
    ga.getXMLAnswer(function(response) {
        console.log("Server Response:", response);
        if (response === "success") {
            alert("Manager change request submitted. Waiting for approval.");
            location.reload();
            alert("Failed: " + response);
// :white_check_mark: Update sys_id when a manager is selected
function updateSysId(sysId) {
    document.getElementById("new_manager_sys_id").value = sysId;
</script>
<div class="container">
    <h2>Change Contractor Manager Request</h2>
    <form id="changeContractorForm">
        <!-- Display the contractor's name (read-only) -->
        <label for="contractor_name_display">Contractor Name</label>
        <input type="text" id="contractor_name_display" value="${gs.getUser().getDisplayName()}" readonly="readonly" />
        <!-- Hidden field to pass the contractor's sys_id -->
        <input type="hidden" id="contractor_sys_id" name="contractor_name" value="${gs.getUserID()}" />
        <!-- Manager Selection Field -->
        <label for="new_manager">New Manager Name</label>
        <g:macro_invoke macro="ui_reference"
            id="ref_sys_user"
            name="new_manager"
            table="sys_user"
            show_popup="true"
            query="active=true"
            onchange="updateSysId(this.value);" />
        <!-- Hidden field to store the sys_id of selected manager -->
        <input type="hidden" id="new_manager_sys_id" name="new_manager_sys_id" />
        <button type="button" class="submit-btn" onclick="onSubmit()">Submit</button>
    </form>
</div>
</j:jelly>
Script include
var ChangeContractorManagerHandler = Class.create();
ChangeContractorManagerHandler.prototype = {
    initialize: function() {},
    createRequest: function(contractor, newManager) {
        try {
            var gr = new GlideRecord('u_change_contractor_manager');
            gr.initialize();
            gr.u_contractor_name = contractor; // Ensure this is a REFERENCE field (sys_id)
            gr.u_new_manager = newManager; // Ensure this is a REFERENCE field (sys_id)
            gr.u_status = 'Pending';
           gr.u_requested_by = gs.getSession().getUserID();
            gr.u_appproval_status = 'Pending Approval'; // Fixed typo
            var budgetOwner = this.getBudgetOwner(contractor);
            if (budgetOwner) {
                gr.u_budget_owner = budgetOwner; // Ensure this is a REFERENCE field
                gs.error("Budget owner not found for contractor: " + contractor);
                return "Budget owner could not be found.";
            var sysId = gr.insert();
            if (sysId) {
                gs.info("Request created: " + sysId);
                return "success";
                gs.error("Failed to create request for contractor: " + contractor);
                return "Failed to create the request.";
        } catch (e) {
            gs.error("Error in createRequest: " + e.message);
            return "Error: " + e.message;
    getBudgetOwner: function(contractorID) {
        var userGR = new GlideRecord('sys_user');
        if (userGR.get(contractorID)) {
            // Replace "u_budget_owner" with the actual field name in your sys_user table
          var budgetOwner = userGR.getValue('u_budget_owner');
            return budgetOwner;
            gs.error("Contractor not found: " + contractorID);
            return null;
    type: 'ChangeContractorManagerHandler'
    var ga = new GlideAjax('ChangeManagerRequest');
    ga.addParam('sysparm_contractor', contractorSysId);
    ga.addParam('sysparm_new_manager', newManagerSysId);
    ga.addParam('sysparm_requested_by', gs.getUserID()); // Fix
        if (response === "Request Created Successfully") {
            alert("Manager change request submitted.");
            location.reload();
// Problem is - it is not saving anything in the u_change_contractor_manager record
rohansargar
Mega Guru
<style>
body {
display: flex;
height: 100vh;
margin: 80px;
padding: 80px;
.container {
width: 700px;
background: white;
padding: 40px;
border-radius: 8px;
margin-top: 20px;
h2 {
text-align: center;
color: #333;
font-size: 28px;
form {
display: flex;
label {
font-weight: bold;
display: block;
margin: 15px 0 8px;
input, select {
width: 100%;
padding: 12px;
border-radius: 4px;
button.submit-btn {
width: 100%;
padding: 12px;
color: white;
border: none;
border-radius: 4px;
font-size: 18px;
cursor: pointer;
margin-top: 20px;
</style>
<script>
location.reload();
// Update sys_id when a manager is selected
</script>
<input type="hidden" id="contractor_sys_id" name="contractor_sys_id" value="${gs.getUserID()}" />
id="ref_sys_user"
name="new_manager"
table="sys_user"
show_popup="true"
query="active=true"
</form>
</div>
</j:jelly>
Please try this code
mark as helpful if you got solution for your issue.
Best Regards,
Rohan.
