Unable to populate Requested for.location in SCTASK Location field when Requested for in SCTASK changes
Gian1
We have a requirement that when the SCTASK requested for field changes the job location field gets populated base on the the requested for location. This does not work. Any ideas or any help will be much appreciated.
I have created a business rule on the sc_request table;
update is true
Filter conditions
Requested for changes
Script;
    var ritm = new GlideRecord('sc_req_item');
    ritm.get(current.getValue('table_sys_id'));
    //if return something
    if (ritm == true) {
        var sctask = new GlideRecord('sc_task');
        sctask.addQuery('request_item', current.getValue('table_sys_id'));
        sctask.query();
        while (sc_task.next()) {
            current.location = current.request.requested_for.location;
 sctask.update();
})(current, previous);
So the code needs slight adjustment if the requested for field on your sc_task is from sc_req table. This business rule will need to be created on the sc_req table, as the requested for field will be changing there when changed on the sc_task dot walked field.
	var userChange = current.requested_for.location;
	var requestSysid = current.getUniqueValue();
	var scTaskRecord = new GlideRecord('sc_task');
	scTaskRecord.addQuery('request', requestSysid);
	scTaskRecord.query();
	while(scTaskRecord.next()){
		scTaskRecord.location = userChange;
		scTaskRecord.update();
If this information helped resolve your issue, please remember to mark response correct and thumbs up to help future community members on this information, thanks!
