Update REQ short description and description in Flow Designer
Zack9
Hi, I'm trying to update the Description and Short Description of a REQ (not RITM).
I have a simple catalog item and flow that generates 1 RITM and 1 Task. How can I populate the REQXXXXXXX short description and description fields with catalog variables?
Thank you for any tips!
@Zack9
use Lookup record first on REQ table
You have RITM record so you can get REQ sysId and it will help you query REQ
then use Update Record action
In the step 4
  1. Look Up Request Record (Look Up Record)
    1. Table sc_request
    2. condition - sys ID  is  (3 - Update Record - Requested Item Record - request - sysid
Do you update any more conditions ?
