User criteria match all on location and group
Daniela18
Hi
I want a user criteria to both match user group and a location that is on the user.
But this doesn't work. Do I have to script? I am novice at scripting, How would such a script look?
I would encourage to have step by step debug
1) check if member of Hardware is able to access the catalog
Keep Script as: Test with user
answer = gs.getUser().isMemberOf('Hardware');
Next
2) check if user's location condition is satisfied
Keep Script as: Test with user having that location
answer = ifScript();
function ifScript(){
var user = new GlideRecord('sys_user');
user.addQuery('sys_id', gs.getUserID());
user.addQuery('location', '25ab9d720a0a0bb300793d3a6b891f82');
user.query();
var locationValid = user.hasNext();
return locationValid;
3) Now combine both the codes and check by adding logs
If my answer solved your issue, please mark my answer as ✅ Correct & 👍Helpful based on the Impact.
19 REPLIES 19
Did you add logs to verify which flag is not coming as true
answer = isValid();
function isValid(){
var isMember = gs.getUser().isMemberOf('Hardware');
gs.info('isMember is ' + isMember);
user.query();
gs.info('locationValid is: ' + locationValid);
if(isMember == true && locationValid == true){
return true;
else{
return false;
I tried this script. Now no-one can see it, regardless :-P. I tried it in my own instance and then impersonated a user that is both member of hardware and the adress and she cannot access it at all.
Isn't it enough to have Hardware in the group and only base script solely on the location?
Hi Daniela,
through above script when both condition match then it would evaluate to true
What came in for logs did you check
so the logs doesnt really tell me anything.
I removed your script and added it again and saved and then tried again. If a user does not have neither location or hardware, it cannot access at all
But if the user has the hardware but not the location, it can access
in logs it says:
please try this
answer = isValid();
function isValid(){
user.query();
if(isMember.toString() == 'true' && locationValid.toString() == 'true'){
return true;
else{
return false;
