User Not Authenticated Issue in Rest call
sri83
Hi Team,
I am creating outbound Rest for creating the update set record in another system but i am getting the error as below.
I have given the required integration roles to that account and also used same credentials to another REST it's working and creating the record.
But when i used same credentials to this REST i am getting the error.
I wanted know on thing,is it possible to create update set record from one instance to another instance?
Sri
MrMuhammad
If the same credentials working fine for other REST calls then you might look into the roles assigned to your service account. As I can see you are trying to write data in update set table so you need admin or teamdev_user roles for create/write. Also, please make sure you are passing in sys_id of target record that you need to update.
Please mark this correct & helpful if it answered your question.
Thanks & Regards,
Sharjeel
Ankur Bawiskar
Hope you are doing good.
Let me know if I have answered your question.
If so, please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
Hitoshi Ozawa
If you can, try the method outlined in the following article using a curl command to see if you can post from a command line.
https://community.servicenow.com/community?id=community_question&sys_id=9e18f118dbdb6780fa192183ca96...
