Using theme builder when marking as default a theme is changing again to Polaris.
Samuel Moya cam
I am using the theme builder to create a custom theme, when marking this as default it changes to the Polaris theme again.
Any idea?
Thank you and best regards.
So the problem was that when marking as default I was in the incorrect scope and the change was not being made.
Dr Atul - LNG
Hi @Samuel Moya cam
https://www.servicenow.com/community/developer-forum/setting-a-default-theme-not-working/m-p/1998997
Check @brianlan25  reply.
I used that but still not working.
Did you try with cache.do
try this and then test.
