What is ECC queue in MidServer, where it is resides .
chanikya
What is ECC-Queue, where it is Resides ( Means on Servicenow instance Or Client network Environment )
what is Probes in MidServer ( how can i understand it ).
Table(in Servicenow)---ECC-----Probes-----MidServer------Devices(Client NetWork)-------MidServer------Sensors------Update into CMDB.
Mark as Correct/Helpful if it helps you to find your solution.
Apurva Malewadikar
www.DXSherpa.com
9 REPLIES 9
Apurva Malewadikar
www.DXSherpa.com
Please don't mine,  iam asking same question here
i just getting confusion here please help me, as per your words [ probes perform data collection and update the CMDB with the help of sensor. ]
Probes revices inforamtion about devices with help of Sensors and sending to ECC table , ECC updates information respective CMDB table.
i confused here , with this structure , can you please explain it.
Table(in Servicenow)---ECC-----Probes-----MidServer------Devices(Client NetWork)-------MidServer------Sensors------Update into CMDB(table in Servicenow)?
can you elaborate it
Input and output u can see in ecc_queue table.
Servicenow gives input to Mid Server,Mid-Server executes probes(like shazzam in discovery...etc) on devices collects information and gives back to mid server as output ..then sensor will segregate received info and updates into CMDB.
(for more you can ref Discovery Docs)
Apurva Malewadikar
www.DXSherpa.com
So Sensors will updates the CMDB table in servicenow .
Thanks for your information !! Thanks a Lot
Yes.right.
Mark my answer as Correct/Helpful so that it will help others to find the solution quickly.
Apurva Malewadikar
www.DXSherpa.com
