What is the best way to reclaim consumables?
snowenthusiast
I am working on Asset management implementation. I know how to assign/consume consumables (using consume button) but what is the best way to reclaim that consumable if person leaves the organization (or any other applicable) use case?
Thanks in advance.
11 REPLIES 11
rpc001 - Thanks for sharing the suggestion. I didn't see any attachment. Can you please share UI action code and page code.
Thanks.
Hi snowenthusiast,
The attachments are at the very bottom of my previous post, below the screenshot.
Hi Robert,
This is great - just what we needed.   I've rolled this out in our Dev/Test and am now seeing that it's not merging the record back on reclaim into the same stockroom selected.   Wondering if this is supposed to occur?   Or if this might be specific to Jakarta?
Hi Angela,
I just loaded this into a fresh Jakarta instance and it still appeared to work there.   Is it possible that the stockroom field on Asset, in your environment, has been modified?   It's hard to say what may be causing the issue without knowing your environment.   The intention is that the consumable is placed back to in stock in the stockroom selected in the pop-up.
hi I downloaded xml and import it into my environment but I can not find it after upload completed.  There are no errors.  We are running on London version.  Please help!
