What is the difference between form sections and related tabs in servicenow demo instance,can we use only one instead of both?
Ram141
Difference between form sections and related tabs in servicenow demo instance,can we use only one instead of both?
Ram141
Hi Slawek,
Thanks for the reply,form sections are not mandatory that needs to be related to the form.
where as Related lists values must be related to the current opened form i'm i correct?
Kuchi
Sections are showing fields from current table or related tables you want to see there.
Related values are related tickets, ci, changes, attachments, etc. anything which is connected to current record.
RajP79032538207
Mega Guru
Users can expand or collapse form sections to show or hide the fields they need. If you have tabs enabled, each form section appears on a separate tab. The default Change Request form is an example of a form with multiple sections as shown in the following image.
and if you do not want the section in tabbed form than you can seperate that in different sections also.
NOTE: Mark correct or helpful if it helps you.
Warm Regards,
Raj patel
