How to explore serviceNow Data with Power BI
leviyabl
hi
Could anyone explain how to explore serviceNow data with power bi ?
19 REPLIES 19
Our instance uses SSO, so to navigate directly to the URL for the api and then to authenticate, I had to have a local password set on my user account within ServiceNow.
Sandeep58
Can someone provide steps how to integrate Power BI with Snow?
Thanks!
Hi Sandeep, that's what we all are looking for, from what I've understood there isn't any. There used to be a PowerBI connector for ITSM Incident Management which was recently deprecated.
I have been using the REST Api Explorer to generate the URL strings for the different tables that we are needing to report data out to PowerBI from. Once I have those API url's, I have setup a serviceaccount on the user table and checked the attribute, Web service access only on the record. I then have provided it with the rest_service and rest_service_explorer role as well as any read roles for tables it will be accessing based on the ACLs for that table. Example, it_project_user when accessing Project data.
I then provide the API url's to our analytics teams and they are using the Get Date > Web option from PowerBi. https://docs.microsoft.com/en-us/power-bi/desktop-connect-to-web
I have been making sure to provide them a url that includes sysparm_display_value=all so that they are not just getting sys_id's for reference values. Depending on what they are needing to do though they are connecting to other tables such as the user table to pull additional data.
Good luck!
-Chris
Thanks a lot Chris for elaborating the process to integrate snow with Power BI .
Trying to go with REST API method for this one .
Sandeep
