Issue setting KB article state to Outdated
abhishekrav
Hi I have recently experienced that few of the previous versions of KB articles are not set to Outdated state.
Due to this users are not able to see Checkout UI action.
Can you suggest how can we move the workflow state to Outdated because i am not able to find the choice as outdated on that field.
2 ACCEPTED SOLUTIONS
KrishnaMohan
Tera Sage
Hi @abhishekrav
1) I have recently experienced that few of the previous versions of KB articles are not set to Outdated state.
  •  When a new version of a KB article is published, the out-of-the-box (OOTB) behavior in ServiceNow is to set the workflow_state of the previous published version to Outdated. The "Checkout" UI action is designed to only be visible on the most current, published version of an article. When previous versions remain in the "Published" state, it can confuse the system and prevent the "Checkout" button from appearing on the correct article.
2)  Due to this users are not able to see Checkout UI action -
  • Have you installed com.snc.knowledge_advanced plugin. If yes why users are not able to see checkout ui action? did you customize the ui action? or did you verify the ui action condition ?(!(new KBCommon().isStackNameDialog()) && (new KBCommon().isVersioningEnabled()) && (new KBVersioning().canCheckout(current)))?
3) Can you suggest how can we move the workflow state to Outdated because i am not able to find the choice as outdated on that field.  -
  •    The reason you don't see "Outdated" as a choice on the workflow_state field is because it's not a user-selectable option in the standard workflow. It is a state that is managed by the system's behind-the-scenes logic when article versioning is enabled.
However to move the workflow state to Outdated  you'll need to manually correct the workflow_state for the affected articles. The most effective and recommended way to do this is by using a background script.
Example Background script
var updateArticle = new GlideRecord('kb_knowledge');
updateArticle .addEncodedQuery('workflow_state=published^number=KB0012345^version<3.0'); // Adjust the query based on your requirement.
// Or, if you want to update a specific article by its sys_id:
// var updateArticle = new GlideRecord('kb_knowledge');
// updateArticle .get('sys_id_of_the_old_article');
updateArticle .query();
while (updateArticle .next()) {
    // Set the workflow_state to 'Outdated'
    updateArticle .workflow_state = 'outdated';
    updateArticle .setWorkflow(false);
    updateArticle .update();
Check Article to know more about article versing in ServiceNow
If this helped to answer your query, please mark it helpful & accept the solution.
Thanks!
Krishnamohan
Thanks for you help!, I have Written a Background script for the same and it worked, The reason it was not moved to outdated state because the KB article is very old around 10 years so the logs have got erased as i have recently enabled versioning this issue has occured.
