Need help on Generate a Report
AshishKumar1
I am looking for a kind of report on which 4 columns will display in a bar chart. Could you please assist to generate the report. Thanks
Hi @AndersBGS ,
Thank you for your help. It' s not going to help in my case .
3 fields = a, b, c which are all time fields.
need to generate a bar report where each bar is one of these fields basically . x axis contains 3 fields & y axis show the duration.
Hi @AshishKumar1 ,
Ok, I understand. From the top of my head according to your requirement, then I do believe that you need to look towards performance analytics, as there is much more possibilities for configuration.
Best regards
Anders
Best regards
Anders
Rising star 2024
MVP 2025
Nivedita Patil
Hi @AshishKumar1 ,
You can follow the below steps for report creation.
1. Open Report module. select view/Run . click on create a report.
2. Fill the form. select the correct source type.
3.  In Type section select bars.
4. In configuration section select group by.
Mark my answer as accepted solution and helpful if helps you.
Nivedita Patil
