Need help with the script to calculate the duration between 2 dates
Rohit8
Wish you all a very Happy New Year.
I am trying to build an Indicator to calculate the Summed age of Assets (to later find out the Average age). The asset table has the columns for Release Date and Retired Date and I need to calculate their difference. The screenshot (A) has the format of the dates.
The 2nd screenshot has the script screen and I am using the above variables. I am not proficient with scripts at all so I am pretty sure I am doing something totally wrong.
var diff=function(x,y){return y.dateNumericValue() - x.dateNumericValue();};
var years=function(x,y){return diff(x,y)/(365*24*60*60*1000);};
years(current.u_avg_hw_release_date, current.retired_date_at);
The job returns the error:
Error during JavaScript evaluation com.snc.pa.dc.ScriptException: JavaScript evaluation returned: NaN in script: var diff=function(x,y){return y.dateNumericValue() - x.dateNumericValue();};
at com.snc.pa.dc.Script.handleException(Script.java:215)
at com.snc.pa.dc.Script.evaluate(Script.java:179)
at com.snc.pa.dc.Script.evaluate(Script.java:156)
at com.snc.pa.dc.DataCollector.collect(DataCollector.java:261)
at com.snc.pa.dc.DataCollector.collect(DataCollector.java:214)
at com.snc.pa.dc.DataCollector.collect(DataCollector.java:172)
at com.snc.pa.dc.DataCollectorJob.collect(DataCollectorJob.java:246)
at com.snc.pa.dc.DataCollectorJob.collectWithMutex(DataCollectorJob.java:162)
at com.snc.pa.dc.DataCollectorJob.execute(DataCollectorJob.java:147)
at com.glide.schedule.JobExecutor.executeJob(JobExecutor.java:103)
at com.glide.schedule.JobExecutor.execute(JobExecutor.java:89)
at com.glide.schedule.GlideScheduleWorker.executeJob(GlideScheduleWorker.java:219)
at com.glide.schedule.GlideScheduleWorker.lambda$process$39(GlideScheduleWorker.java:161)
at com.glide.worker.TransactionalWorkerThread.executeInTransaction(TransactionalWorkerThread.java:35)
at com.glide.schedule.GlideScheduleWorker.process(GlideScheduleWorker.java:161)
at com.glide.schedule.GlideScheduleWorker.run(GlideScheduleWorker.java:72)
Caused by: java.lang.Exception: JavaScript evaluation returned: NaN
... 15 more
Can anyone help me correct the script or let me know what am I doing wrong.
Thanks a lot.
Last try
var sgd1 = new GlideDate();
var sgd2 = new GlideDate();
sgd1.setDisplayValue(current.retired.getDisplayValue());
sgd2.setDisplayValue(current.u_abg_hw_release_date.getDisplayValue());
var duration = GlideDate.subtract(sgd1, sgd2);
Math.floor(duration.getDayPart()/365);
Cheers,
Thilo
12 REPLIES 12
Last try
Cheers,
Thilo
Thank you so much for your help so far.
So, I saved the script and ran the job and finally it ran without any errors (but it did have warnings) !!
When I checked the Indicator scorecard, it doesn't seem to have any score at all and has 0 instead (because of what I selected for Value when Nil).
Data Collector logs:
SequenceSortCreatedSortLevelSortMessageSortSourceSort
125
07-Jan-18 01:32:31
WarningNo data was collected between 01-Jan-08 and 31-Dec-08 for indicator "Summed age of Assets (Desktops)" in the indicator source "Assets.Workstations.Yearly". Data within this range is older than the maximum age, based on the indicator frequency and collection periods.DataCollector
88
07-Jan-18 01:32:29
WarningNo list of records (snapshot) was collected between 01-Jan-04 and 01-Jan-11 for indicator source "Assets.Workstations.Yearly". Snapshot within this range is older than the maximum age, based on indicator frequency and snapshot periods, for all indicators associated with this indicator source.DataCollector
126
07-Jan-18 01:32:31
WarningNo data was collected between 01-Jan-04 and 01-Jan-08 for indicator source "Assets.Workstations.Yearly". Data within this range is older than the maximum age, based on indicator frequency and collection periods, for all indicators associated with this indicator source.DataCollector
87
07-Jan-18 01:32:29
WarningNo list of records (snapshot) was collected between 01-Jan-11 and 31-Dec-11 for indicator "Summed age of Assets (Desktops)" in the indicator source "Assets.Workstations.Yearly". Snapshot within this range is older than the maximum age, based on the indicator frequency and snapshot periods.DataCollector
122
07-Jan-18 01:32:31
InformationStored 'Value when nil': 0.0 as score for indicator: Summed age of Assets (Desktops)DataCollector
22
07-Jan-18 01:32:10
InformationDeleted previous results 0DataCollector
61
07-Jan-18 01:32:24
InformationStored collected resultsDataCollector
6
07-Jan-18 01:31:58
InformationFetched 20,538 rows from alm_hardwareDataCollector
130
07-Jan-18 01:32:31
InformationAnalyzed table pa_snapshots successfullyDataCollector
50
07-Jan-18 01:32:21
InformationCollecting for 20150101 finishedDataCollector
8
07-Jan-18 01:32:04
InformationApplied map/reduce functionDataCollector
67
07-Jan-18 01:32:24
InformationApplying map/reduce function for indicator source Assets.Workstations.YearlyDataCollector
103
07-Jan-18 01:32:30
InformationSELECT alm_hardware0.`sys_id` FROM ((alm_hardware alm_hardware0 INNER JOIN alm_asset alm_asset0 ON alm_hardware0.`sys_id` = alm_asset0.`sys_id` ) LEFT JOIN cmdb_model cmdb_model1 ON alm_asset0.`model` = cmdb_model1.`sys_id` ) WHERE alm_asset0.`install_status` IN (6 , 1) AND cmdb_model1.`u_subcategory` IN ('Desktops' , 'Laptop' , 'Notebooks') AND alm_asset0.`u_avg_hw_release_date` <= '2010-12-31'DataCollector
82
07-Jan-18 01:32:29
100
07-Jan-18 01:32:30
InformationCollecting for 20110101 finishedDataCollector
109
07-Jan-18 01:32:31
InformationStoring collected results for indicator source Assets.Workstations.YearlyDataCollector
23
07-Jan-18 01:32:10
110
07-Jan-18 01:32:31
38
07-Jan-18 01:32:16
InformationCollecting for 20160101 finishedDataCollector
107
07-Jan-18 01:32:31
InformationDeleting previous results for indicator source Assets.Workstations.YearlyDataCollector
132
07-Jan-18 01:32:31
InformationCollection endedDataCollector
51
07-Jan-18 01:32:21
InformationCollecting for 20140101DataCollector
9
07-Jan-18 01:32:04
78
07-Jan-18 01:32:27
InformationFetched 7,255 rows from alm_hardwareDataCollector
108
07-Jan-18 01:32:31
91
07-Jan-18 01:32:29
InformationSELECT alm_hardware0.`sys_id` FROM ((alm_hardware alm_hardware0 INNER JOIN alm_asset alm_asset0 ON alm_hardware0.`sys_id` = alm_asset0.`sys_id` ) LEFT JOIN cmdb_model cmdb_model1 ON alm_asset0.`model` = cmdb_model1.`sys_id` ) WHERE alm_asset0.`install_status` IN (6 , 1) AND cmdb_model1.`u_subcategory` IN ('Desktops' , 'Laptop' , 'Notebooks') AND alm_asset0.`u_avg_hw_release_date` <= '2011-12-31'DataCollector
113
07-Jan-18 01:32:31
InformationCollecting for 20090101DataCollector
117
07-Jan-18 01:32:31
106
07-Jan-18 01:32:31
114
07-Jan-18 01:32:31
InformationFetching "model.u_subcategory,sys_id,u_avg_hw_release_date,install_status,retired" from "alm_hardware"DataCollector
111
07-Jan-18 01:32:31
13
07-Jan-18 01:32:04
1
07-Jan-18 01:31:56
InformationStarting collectionDataCollector
10
07-Jan-18 01:32:04
42
07-Jan-18 01:32:16
InformationFetched 16,790 rows from alm_hardwareDataCollector
116
07-Jan-18 01:32:31
InformationFetched 319 rows from alm_hardwareDataCollector
92
07-Jan-18 01:32:30
InformationFetched 3,355 rows from alm_hardwareDataCollector
30
07-Jan-18 01:32:11
InformationFetched 19,485 rows from alm_hardwareDataCollector
97
07-Jan-18 01:32:30
115
07-Jan-18 01:32:31
InformationSELECT alm_hardware0.`sys_id` FROM ((alm_hardware alm_hardware0 INNER JOIN alm_asset alm_asset0 ON alm_hardware0.`sys_id` = alm_asset0.`sys_id` ) LEFT JOIN cmdb_model cmdb_model1 ON alm_asset0.`model` = cmdb_model1.`sys_id` ) WHERE alm_asset0.`install_status` IN (6 , 1) AND cmdb_model1.`u_subcategory` IN ('Desktops' , 'Laptop' , 'Notebooks') AND alm_asset0.`u_avg_hw_release_date` <= '2009-12-31'DataCollector
31
07-Jan-18 01:32:11
129
07-Jan-18 01:32:31
InformationStarting to analyze table pa_snapshotsDataCollector
120
07-Jan-18 01:32:31
54
07-Jan-18 01:32:21
InformationFetched 12,346 rows from alm_hardwareDataCollector
12
07-Jan-18 01:32:04
17
07-Jan-18 01:32:04
InformationSELECT alm_hardware0.`sys_id` FROM ((alm_hardware alm_hardware0 INNER JOIN alm_asset alm_asset0 ON alm_hardware0.`sys_id` = alm_asset0.`sys_id` ) LEFT JOIN cmdb_model cmdb_model1 ON alm_asset0.`model` = cmdb_model1.`sys_id` ) WHERE alm_asset0.`install_status` IN (6 , 1) AND cmdb_model1.`u_subcategory` IN ('Desktops' , 'Laptop' , 'Notebooks') AND alm_asset0.`u_avg_hw_release_date` <= '2017-12-31'DataCollector
55
07-Jan-18 01:32:21
96
07-Jan-18 01:32:30
74
07-Jan-18 01:32:27
InformationCollecting for 20130101 finishedDataCollector
101
07-Jan-18 01:32:30
InformationCollecting for 20100101DataCollector
105
07-Jan-18 01:32:31
60
07-Jan-18 01:32:24
98
07-Jan-18 01:32:30
59
07-Jan-18 01:32:24
56
07-Jan-18 01:32:24
2
07-Jan-18 01:31:56
InformationProcessing Indicator Source Assets.Workstations.YearlyDataCollector
90
07-Jan-18 01:32:29
45
07-Jan-18 01:32:20
19
07-Jan-18 01:32:04
104
07-Jan-18 01:32:31
InformationFetched 1,427 rows from alm_hardwareDataCollector
3
07-Jan-18 01:31:58
InformationCollecting for 20180101DataCollector
69
07-Jan-18 01:32:27
26
07-Jan-18 01:32:10
InformationCollecting for 20170101 finishedDataCollector
64
07-Jan-18 01:32:24
102
07-Jan-18 01:32:30
39
07-Jan-18 01:32:16
InformationCollecting for 20150101DataCollector
65
07-Jan-18 01:32:24
InformationSELECT alm_hardware0.`sys_id` FROM ((alm_hardware alm_hardware0 INNER JOIN alm_asset alm_asset0 ON alm_hardware0.`sys_id` = alm_asset0.`sys_id` ) LEFT JOIN cmdb_model cmdb_model1 ON alm_asset0.`model` = cmdb_model1.`sys_id` ) WHERE alm_asset0.`install_status` IN (6 , 1) AND cmdb_model1.`u_subcategory` IN ('Desktops' , 'Laptop' , 'Notebooks') AND alm_asset0.`u_avg_hw_release_date` <= '2013-12-31'DataCollector
81
07-Jan-18 01:32:29
84
07-Jan-18 01:32:29
49
07-Jan-18 01:32:20
16
07-Jan-18 01:32:04
21
07-Jan-18 01:32:10
124
07-Jan-18 01:32:31
InformationCollecting for 20090101 finishedDataCollector
73
07-Jan-18 01:32:27
68
07-Jan-18 01:32:27
32
07-Jan-18 01:32:16
62
07-Jan-18 01:32:24
InformationCollecting for 20140101 finishedDataCollector
33
07-Jan-18 01:32:16
93
07-Jan-18 01:32:30
14
07-Jan-18 01:32:04
InformationCollecting for 20180101 finishedDataCollector
24
07-Jan-18 01:32:10
89
07-Jan-18 01:32:29
InformationCollecting for 20110101DataCollector
44
07-Jan-18 01:32:20
25
07-Jan-18 01:32:10
20
07-Jan-18 01:32:10
119
07-Jan-18 01:32:31
77
07-Jan-18 01:32:27
InformationSELECT alm_hardware0.`sys_id` FROM ((alm_hardware alm_hardware0 INNER JOIN alm_asset alm_asset0 ON alm_hardware0.`sys_id` = alm_asset0.`sys_id` ) LEFT JOIN cmdb_model cmdb_model1 ON alm_asset0.`model` = cmdb_model1.`sys_id` ) WHERE alm_asset0.`install_status` IN (6 , 1) AND cmdb_model1.`u_subcategory` IN ('Desktops' , 'Laptop' , 'Notebooks') AND alm_asset0.`u_avg_hw_release_date` <= '2012-12-31'DataCollector
41
07-Jan-18 01:32:16
InformationSELECT alm_hardware0.`sys_id` FROM ((alm_hardware alm_hardware0 INNER JOIN alm_asset alm_asset0 ON alm_hardware0.`sys_id` = alm_asset0.`sys_id` ) LEFT JOIN cmdb_model cmdb_model1 ON alm_asset0.`model` = cmdb_model1.`sys_id` ) WHERE alm_asset0.`install_status` IN (6 , 1) AND cmdb_model1.`u_subcategory` IN ('Desktops' , 'Laptop' , 'Notebooks') AND alm_asset0.`u_avg_hw_release_date` <= '2015-12-31'DataCollector
63
07-Jan-18 01:32:24
InformationCollecting for 20130101DataCollector
127
07-Jan-18 01:32:31
InformationStarting to analyze table pa_scoresDataCollector
37
07-Jan-18 01:32:16
85
07-Jan-18 01:32:29
18
07-Jan-18 01:32:04
28
07-Jan-18 01:32:10
86
07-Jan-18 01:32:29
InformationCollecting for 20120101 finishedDataCollector
53
07-Jan-18 01:32:21
InformationSELECT alm_hardware0.`sys_id` FROM ((alm_hardware alm_hardware0 INNER JOIN alm_asset alm_asset0 ON alm_hardware0.`sys_id` = alm_asset0.`sys_id` ) LEFT JOIN cmdb_model cmdb_model1 ON alm_asset0.`model` = cmdb_model1.`sys_id` ) WHERE alm_asset0.`install_status` IN (6 , 1) AND cmdb_model1.`u_subcategory` IN ('Desktops' , 'Laptop' , 'Notebooks') AND alm_asset0.`u_avg_hw_release_date` <= '2014-12-31'DataCollector
72
07-Jan-18 01:32:27
29
07-Jan-18 01:32:10
InformationSELECT alm_hardware0.`sys_id` FROM ((alm_hardware alm_hardware0 INNER JOIN alm_asset alm_asset0 ON alm_hardware0.`sys_id` = alm_asset0.`sys_id` ) LEFT JOIN cmdb_model cmdb_model1 ON alm_asset0.`model` = cmdb_model1.`sys_id` ) WHERE alm_asset0.`install_status` IN (6 , 1) AND cmdb_model1.`u_subcategory` IN ('Desktops' , 'Laptop' , 'Notebooks') AND alm_asset0.`u_avg_hw_release_date` <= '2016-12-31'DataCollector
123
07-Jan-18 01:32:31
118
07-Jan-18 01:32:31
Bottom of table
I have been getting the errors about Maximum age when I try to go further back than 2010 with other indicators, but they do return the latest results from last 6-7 years. And there are Assets in the table with the Release and Retired Data both from last 6-7 years,
Thank you.
Thilo,
I figured it out. I checked my Indicator trail and it turned out that the 0 result was due to the Indicator source not configured to include the "Retired" machines. It was only set up to include the "In stock" or "In use" machines. Hence, it was not able to use the Retired machines in the calculation thus had nothing to calculate.
After correcting that, your script worked like a charm !!
In fact, the script I provided initially worked fine too after correcting the field names.
years(current.u_avg_hw_release_date,current.retired);
I can't thank you enough for hanging through this, with me.
Sorry for all the headache I might've caused you.
