problem module is not visible in filter navigation.
Sandeepkumar97
problem module is not visible  in filter navigatio but if i search problem.list it opens
JenniferRah
Out of the box, that menu item is visible to the itil, problem_task_analyst, and sn_problem_read roles. If you need to change that, go to System Definition -> Application Menus and open the record named "Problem".  You can change the roles that it is visible to in there.
Tanushree Maiti
Hi @Sandeepkumar97
Just Repair the Problem and change management plugin and Try . Your problem will be resolved.
Problem Management plugin [com.snc.problem]
Mohammed8
Hi @Sandeepkumar97
Faced similar issue with another module.
1) Try to update the plugin to latest (check with your team before doing so)
2) Repair the plugin
its_SumitNow
Hi @Sandeepkumar97  , I came across the same problem on my PDI, I repaired the com.snc.problem plugin, & it started appearing in application navigator , this will work for you also
Hope my response Helps šŸ™‚, if yes kindly mark it helpful & Accept as Solution
Sumit
