Flow designer - Script Action
GwynethPhoS
I cant seem to find the Script Action in Flow Designer. How to make it visible in my flow?
@GwynethPhoS
11 REPLIES 11
Tejas Adhalrao
Hi @GwynethPhoS  ,
here you can create the action to run scripts
1)
2)give name to action and click build action
3)click on + icon
4) add select script
5) now provide the input and for your action and write you script and save it and dont forget to Publish
6) now in your Flow designer you can use your action
also you can refer this Youtube videos for more clarifications
https://youtu.be/HQZCUQQd0ro?si=TOJcWSmKoNHmzi0W
 If you found my solution helpful, please mark it as Helpful or Accepted Solution...!
thanks,
tejas
Email: adhalraotejas1018@gmail.com
LinkedIn: https://www.linkedin.com/in/tejas1018
Aditya_hublikar
Hello @GwynethPhoS ,
Script step is not available directly in Flow Designer flows. It is only available when creating a Custom Action. If scripting is required, create a custom action with a script step and then use that action inside the flow.
If this helps you then mark it as helpful and accept as solution.
Aditya
 I hope you are doing well .Does my response helps you ?
If my response helps you then mark it as helpful and accept as solution.
Aditya
AnkaRaoB
Giga Guru
Hi @GwynethPhoS ,
Script Action is not available directly in a Flow. It is created and managed under Actions in Workflow Studio and can be added to a Flow only after it has been created as a custom Action. Once created, it will be available for selection when building the Flow.
The Script Action is not available directly in a Flow. It is created and managed under Actions in Workflow Studio and can be added to a Flow only after it has been created as a custom Action. Once created, it will be available for selection when building the Flow.
AnkaRaoB
Giga Guru
Hi @GwynethPhoS ,
