Flow designer - Script Action
GwynethPhoS
I cant seem to find the Script Action in Flow Designer. How to make it visible in my flow?
@GwynethPhoS
11 REPLIES 11
yashkamde
Tera Sage
Hello @GwynethPhoS ,
There is nothing like script action, servicenow has only action like in that we write script step which is a different operation you can use in flow designer..
In Short :
Flow - we use action
action - we can use script step
Both combines make scripting logic used in flow designer..
Mohit 101
Giga Guru
Open Flow Designer and click New > Action (do not click Flow).
In the Action Outline on the left, click the plus (+) icon between Inputs and Outputs.
Scroll down to the Step selection and select Script.
Save and Publish the Action.
Go back to your Flow, click Add an Action, and search for the name of the Action you just created.10.jpg
Mark it helpful if this helps you to understand. Accept solution if this give you the answer you're looking for.
Thank You
