Flow Designer - Multiple triggers?
Deborah Mulderr
Kilo Expert
I am automating our leavers process and this can be triggered by a manager completing a leavers form or by access control setting the user to inactive.
Can I use two triggers at the start of my flow in flow designer? If so how?
As both triggers will follow the same process
MrMuhammad
Hi @Deborah Mulderrig ,
You cannot have two different trigger types on flow designer. It would always be a single trigger. You can have your subflow for similar actions but you can create two flows with different triggers if required and just call the subflow inside the flows.
however, I understand the leavers form thing but didn't get how your "access control settings" process is working. Is this another catalog item or something else? Please provide some details for us to understand and give you the best option to proceed further.
Muhammad
Muhammad
Deborah Mulderr
Kilo Expert
Thank you both for your help, much appreciated 🙂
@Deborah Mulderrig - Thanks! If you think your question has been answered then please close the thread by marking the appropriate response as correct which will help future readers with similar queries.
Muhammad
