SAM Pro integration with Procurement systems
Prasad_Sanka
I’m looking for documentation on SAM Pro integration with procurement systems. If you have worked on this or have any information, could you please share it? Thanks in advance!
14 REPLIES 14
Hey Dennis - we've developed an integration with Coupa and to say it was and "OOTB" solution is a stretch to say the least. 🙂
Could you please share if you have any documentation with Coupa integration? Thanks!
Hi @MikeW0609686430,
Sounds great and looks like a high maturity level between procurement and SAM about the required attributes.
How did you managed all the internal steps happend when creating entitlements manually or via entitlement import (e.g., software model creation based on PPN, pre checks that all entitlement requirements are covered which are handled by BR or UI policies, ensure metric group and license metric are valid, etc. …)
Thanks, Dennis
Should my response prove helpful, please consider marking it as the Accepted Solution/Helpful to assist closing this thread.
MercBuilding
What type of documentation are you looking for? and which procurement system you are trying to integarte with
Specific to Integration and step by step instructions.
