Help needed with flow for auto closing Incidents after specific period
AdamUMC
Hi there,
I have this checkbox that shows up when Incident State = "On Hold" and On Hold Reason = "Awaiting Caller".
What I want is, when the Incident is configured with this State, Reason AND checkbox is CHECKED ON, that the Incident is becoming automatically closed after a while if NO reply has come back, which has removed the Incident from it's "On Hold" + "On Hold Reason" and checked checkbox states.
I've created a flow for this, please see here below. This flow causes me at regular base headache, because it does not work as aspected:
1.) I cannot check contineously if the checkbox is becoming FALSE, to update the Incident (write down "log info- rule" into a Work Note).
2.) It's not possible to create a condition where a value CHANGES (from a specific value) to a specific value. I'm now using "IS FALSE".
3.) STEP 2 from the flow is getting ignored; STEP 9 (same action) is getting processed, but AFTER the first block of 3 minutes in the flow are over, instead of immediately.
This duration of 3 minutes, should be in real life 168 hours / 7 days. For testing purposes I have limited this duration time to 3 minutes. You can imagine that if the Caller re-opens the Incident, we want to know that a.s.a.p. (to confirm the flow is working correctly) instead of waiting 3 minutes or in fact 7 days.
How can I fix this? Is it possible to fix this issue? I have tried to write down a notation in a Work Note with a Business Rule, but that seems not to work. Also, a Business Rule would be just a part of the solution; it cannot end this flow while this is a mandatory step to prevent processing all next steps (autoclosure of the re-opened incident).
Thanks!
Mark Manders
Giga Patron
Your flow should only be part of the solution. The flow should start on your trigger condition and then wait for 7 days. At that point you check on the status and to see if that is still the same. If so, close the ticket.
Next to that you can have a flow/BR that handles the update coming in from the client. You let that logic set the state/reason/autoclosure fields and the ticket is back on your radar. If you want, you can add the text in the worknotes as well and use a lookup in your first flow to check if that text was added to the sys_journal_field record for this ticket and if that was within 7 days ago (just in case it is set awaiting for a second time).
Mark
Hi @Mark Manders , thank you for your reply, altough I don't understand everything very well. 🙂
"Your flow should only be part of the solution. The flow should start on your trigger condition and then wait for 7 days. At that point you check on the status and to see if that is still the same. If so, close the ticket."
But I need to send a reminder after the first block of 7 days, and then wait 7 days again, before closing the ticket. Because of this, the second part of your post will not work, right?
Thanks again.
Your wait conditions in the flow take care of the sending of the email and they validate (after each 7 days) if the notification needs to be send or not. They are checking on what the second part of what I wrote did (or didn't) do.
Mark
Btw, this is already configured into a few BR's:
"Next to that you can have a flow/BR that handles the update coming in from the client. You let that logic set the state/reason/autoclosure fields and the ticket is back on your radar."
BR 1:
BR 2:
BR 3:
All of these BR's are "OOTB" BR's. I just added "Autoclosure for On Hold" into the Action tab of each BR (there where was applicable).
Seems the flow is faster with evaluating step 2 (see execution flow), instead of one of the BR's.
If I can solve that, my problem can be solved without the need of any additional actions at the current flow?
