03-28-2022 06:21 AM
Hi Team,
I have created a muti row variable set called-'workflow'
where i have workflow, approver and cc variables as below:
How to call this variables inside the workflow.
In other words, i need to use approver and cc as approvers inside the workflow.
Please help me.
Srivalli M
03-29-2022 12:04 AM
I hope your workflow is running on RITM table if yes the below code will work
Just now tested in my PDI as well.
Keep some logs and try and let me know what logs you have got:
answer = [];
var mrvs = current.variables.workflow; //use MRVS internal name
for (var i = 0; i < mrvs.getRowCount(); i++) {
var row = mrvs.getRow(i); // getting the row one by one using getRow
gs.info("approver"+row.approvers);
gs.info("cc"+row.cc);
answer.push(row.approvers.toString()); //sending approval to approvers users
answer.push(row.cc.toString()); //sending approval to cc users & map your variable names
Murthy
Murthy
03-29-2022 12:07 AM
Hi Ram,
The agend is to get the variables inside the multi row variable set inside my workflow.
like the approvers and cc users as approvers in approval stage inside the workflow.
Please help
Srivalli
