Post Work notes on RITM using script
Rajanmehta
Mega Guru
I am trying to add some work notes on an existing RITM using script (below). I am able to see the record on sys_journal_filed table but doesn't show up on RITM. What am  I missing? Please advise.
Rajan
var grJrnl = new GlideRecord('sys_journal_field');
grJrnl.setValue('name','sc_req_item');
grJrnl.setValue('value','Testing....Again');
grJrnl.setValue('element','work_notes');
grJrnl.setValue('element_id','sys_id of RITM');
grJrnl.insert();
Allen Andreas
I'm unsure where this script is at (like business rule or what) or why you're gliding to journal_field table...but you can simply do:
variable.work_notes = "Text here";
or whatever variable holds your record and do work_notes after it.
Hi @Ishita Shrivastava - this worked for me! Question, what would I write to be able to add another preloaded entry/line within work notes?
I appreciate your help!
