Access variable in RITM from Record producer flow
gdo
Dear community,
Is it possible to bring the variables of my form to the RITM using a record producer ?
I need to create CASE + Service Request
I decided to create case from record producer and use a flow to create SR but I can't see the variables like this :
Any suggestions or other way to have case + sr creation best practice ?
Ankur Bawiskar
@gdo
Variable editor on RITM will only show variables if your current RITM is submitted as part of Catalog item.
You can use "Submit Catalog Item Request" flow action and it will generate Service Request (REQ and RITM)
Submit Catalog Item Request action
You can submit a record producer using script as well
see these links
How to Submit record producer using script ServiceNow
Submit the record producer from script
CatItem - Scoped
gdo
Find the solution over here
https://www.youtube.com/watch?v=BmLtPoeS3Dk
Thank you Ankur, Rhank you robert , thank you all
Launching a Flow from a Record Producer in #ServiceNow is WAY easier than you think. No need to create flow triggers comparing on short description. Absolutely ZERO code required. You just need to know about the sc_item_produced_record table. 🔗LinkedIn: https://www.linkedin.com/in/rfedoruk/ 🎙️ ...
