Auto Populate Fields using Requested For
Blaze2
I have created the following Catalog Item and Form. The idea is for the Training group to fill this form out for new employees.
Currently the Employee Name field will auto populate all of the required fields.
using the following Client Script:
When I get to the Request and Requested Item, the name that is populated as the Requested for is mine. Request.JPG
So I went back to the form, and added the Requested By Variable Set which of course will not populate the needed fields.
My question is to have one of the following occur:
1. Keep the Employee name field which will populate everything as it is now, but also have the name inserted there be the Requested for
2. Change the variable from Employee_name to Requested_for, have it populate all fields and show as the Requested for.
Either option is good for me.
Thanks for your help.
Blaze2
I figured it out.
I needed to change the field name from employee_name to requested_for.
Then in the Client Script I did the same
This would give me the functionality that I needed.
As well as Bring forward the Employee Name as my Requested for in the Request. RITM and the SCTASKfind_real_file.png
Thanks everyone for your help
16 REPLIES 16
A request item is basically a container for a workflow launched by a Catalog Item.
The workflow *IS* your request item.
Take that workflow, drop a run script between the Begin and your first activity.   Populate it with the script I gave you, then you're fine.
I tried it with the run script as you instructed and still a no go
Still getting myself as the Requested For
sachin312
Blaze,
Can you check whether your able to see the record when you move your mouse cursor to icon beside the magnifying glass.
From the task looking at the RITM
