Auto Populate Fields using Requested For
Blaze2
I have created the following Catalog Item and Form. The idea is for the Training group to fill this form out for new employees.
Currently the Employee Name field will auto populate all of the required fields.
using the following Client Script:
When I get to the Request and Requested Item, the name that is populated as the Requested for is mine. Request.JPG
So I went back to the form, and added the Requested By Variable Set which of course will not populate the needed fields.
My question is to have one of the following occur:
1. Keep the Employee name field which will populate everything as it is now, but also have the name inserted there be the Requested for
2. Change the variable from Employee_name to Requested_for, have it populate all fields and show as the Requested for.
Either option is good for me.
Thanks for your help.
Blaze2
I figured it out.
I needed to change the field name from employee_name to requested_for.
Then in the Client Script I did the same
This would give me the functionality that I needed.
As well as Bring forward the Employee Name as my Requested for in the Request. RITM and the SCTASKfind_real_file.png
Thanks everyone for your help
16 REPLIES 16
Blaze2
I figured it out.
SP22
I have the same requirement can you help how to solve this.
