Auto populate reference variable based on another reference variable on a catalog item form. I have reference variable Application referring to 'Name' field on Applications (cmdb_ci_appl) table and another list field called 'Roles' in it. On catalog
09-28-2020 05:12 AM
Auto populate reference variable based on another reference variable on a catalog item form. I have reference variable Application referring to 'Name' field on Applications (cmdb_ci_appl) table and there is a list field called 'Roles' on same table, which has multiple roles associated to each application (these roles are maintained in a separate custom table). On catalog Item I want to populate roles from this list field values in a variable based on the application selected on catalog form.
Hope someone helps me get this! Thank you
Service Catalog
10-06-2020 12:29 AM
Hi Jyotsna,
Glad to hear this.
Just ensure you add this in the variable attributes for the list collector
ref_qual_elements=security
If your query is resolved please mark appropriate response as correct & helpful so that this thread can be closed and others can be benefited by this.
09-13-2021 02:00 AM
Hope you are doing good.
If my response helped you please mark it correct to close the question so that it benefits future readers as well.
