Call of Script Include in an onChange Client Script is not working
Wiem Nabli
I have a Catalog Item having a "Yes/No" variable "u_reprise_donnees" and another variable "u_hierarchique" which references "sys_user" table. If the variable "u_reprise_donnees" has the value "No", I want to fill the variable "u_hierarchique" automatically with the manager of the current user.
To do this, I have created an onChange Client Script on the variable "u_reprise_donnees" and if the new value of this variable is "No" then I call a function in the Script Include which will return the manager of the current user.
The problem is that the manager's value is showing Null and the logs in the Script Include are not showing.
Client Script :
    // If value of "u_reprise_donnees" is "Yes" then show message
    if (newValue == "Yes") {
        g_form.showFieldMsg("u_reprise_donnees", "La demande d'automatisation ne sera pas disponible dans le choix des changements urgents.");
    //else if value is "No" then search for the manager id of the current user and assign it to "u_hierarchique" field
    else if (newValue == "No") {
        var gaUserUtils = new GlideAjax('UserUtils');
        gaUserUtils.addParam('sysparm_name', 'getUserManager');
        gaUserUtils.addParam('sysparm_user_id', g_user.userID);
        gaUserUtils.getXML(ajaxResponse);
function ajaxResponse(response) {
    var managerID = response.responseXML.documentElement.getAttribute("answer");
    alert("Manager is : " + managerID);
    g_form.setValue("u_hierarchique", managerID);
Script Include :
// Get the manager of the user
    getUserManager: function() {
        // Récupération des parametres
        var userId = this.getParameter('sysparm_user_id');
        gs.log("User is : " + userId, "Test");
        var userManager;
        var user = new GlideRecord("sys_user");
        user.addQuery("sys_id", userId);
        user.query();
        if (user.next()) {
            userManager = user.getValue("manager");
        gs.log("Manager is : " + userManager, "Test");
        return userManager;
I really appreciate any help you can provide.
Hitoshi Ozawa
Hi WA,
Tried both Client Script and Script Include and they are working OK.
I've delete the onLoading if statement in Client Script so it'll execute when the form is loaded. I, also, already had Script Include named UserUtils2 so I've named my Script Include "UserUtils2".
    if (newValue == '') {  // remove onLoading
        var gaUserUtils = new GlideAjax('UserUtils2');  // renamed from UserUtils
Execution
case 1: when form is opened.
case 2: when u_reprise_donnees is set to No
If it is not working, it may be with Script Include settings. Make sure "Client callable" is checked. This will generate the following script without "initialize: function() {}," statement.
var UserUtils = Class.create();
UserUtils.prototype = Object.extendsObject(AbstractAjaxProcessor, {
Also, name of the file "UserUtils" should be set in all the the script as follows.
Thank you for your answer, when I removed the function initialize from the Script Include and then added this :
It worked perfectly as you said.
Thank you 🙂
