CAN WE ATTACH WORKFLOW TO A ORDER GUIDE ?? IF SO HOW ?
anoopr77
Kilo Explorer
26 REPLIES 26
I am attaching a wrkflow to an order guide created .
when i am ordering an item , a default wrkflow is gettin attached instaed
inside the RITM , i am getting this errro "There are no workflow contexts for this document" .
Hi Anoop,
Please check if any approval is needed for Request(REQXXXX) and once all approval is done for request you will be able to see the workflow that you have created and attached for that particular catalog item ( on clicking 'Show workflow' link under 'Related links' present on RITM form).
Hi Sita
Really Appreciate your inputs !! will try and get bak to you .
Harish KM
Sanjeev Kumar1
Hi ,
We are using workflow for an Order guide.
for this you need to use following steps.
1. Create your Order Guide.
2. Add Item in order guide using Rule Base.
3. Create Workflow on sc_request table.
4. Set property run this workflow only if Order Guide is "Your Order Guide"
5. Set "Workflow" in order guide.
6. Create one more workflow for your item.
For more details see following http://wiki.servicenow.com/index.php?title=Defining_a_Service_Catalog_Workflow
If you have any problem let me know
Sanjeev Kumar
