CAN WE ATTACH WORKFLOW TO A ORDER GUIDE ?? IF SO HOW ?
anoopr77
Kilo Explorer
26 REPLIES 26
Hi Sanjeev,
how can I do this ?
Set property run this workflow only if Order Guide is "Your Order Guide"
I don't see in 'workflow properties' this option.
Hi Peter,
1. Go to workflow editor.
2. Open your workflow.
3. Open workflow property.
4. Set condition [ Note: Checkout your workflow to update]
Sanjeev Kumar
Hi Sanjeev,
my issue is that I do not have 'Order guide' column on sc_request table.
Is this out-of-the box column ?
Hi Peter,
If you using ServiceNow this is ( Order guide) is must a field in sc_request.
Please check it again.
Or
Provide me access on your instance so that I can help you.
Or
You need to contact ServiceNow Support team.
Sanjeev Kumar
I cannot see it, I also checked some other instances (+ demo instance) and it's neither there (I checked Calgary and Eureka versions).
I'm sorry but I can't give you an access. Otherwise, thank you for your help, but I need to find different approach how to solve it since this is not working for me.
Any other ideas ?
