CAN WE ATTACH WORKFLOW TO A ORDER GUIDE ?? IF SO HOW ?
‎08-22-2014 12:17 AM
‎03-19-2015 10:52 AM
I am very interested in using this approach, but I too cannot find the "Order Guide" condition. Is it a related field?
Thank you for your response
‎04-21-2015 02:30 AM
In order to haeve the Order guide condition, I think that you should refer to this article:
http://www.servicenowguru.com/system-definition/populate-order-guide-request-ticket/
Thad
‎01-28-2017 02:05 AM
Hi Sanjeev Kumar i am also fasing the same issue but i kept the condition that u mentioned for me it is working fine but the issue i am having is both the workflow are getting attached how to make the default workflow false can u provide me some input on this issue it is very very very urgent.
Khaja
‎01-28-2017 02:53 AM
Hi Kaja,
Just change the condition in another workflow so that it will not run when your condition matches.
‎01-28-2017 05:18 AM
Hi Harish Kumar ,
Thanks for Your replay but the another workflow is a default workflow which is triggering
actual scenario is i need to run a req workflow i created custom worflow the condition is working fine which i have given but the issue i am having is both the custom workflow and default workflow are triggering
plzzzzzzzzzzzzzzzz it is a bit urgent can any one help me plzzzzzzzzzzzzzzzz
