Cant view certain fields in survey report using asmt_metric_result
Matt Todd
Hi all,
Ive made a report to display all survey results on the asmt_metric_result table. It works on my admin account, however when i log in as a user there are fields missing. Particularly instance.task.number, instance.task.short_description, instance.task.opened_by, instance.task.assigned_to. Originally none of the survey responses where there. i added the role survey_reader and it made the survey stuff available such as instance number, metric and string value, but not the related task information. Can anyone help identify what im missing here?
Matt Todd
So the instance field links to asmt_assessment_instance. There is an ACL in there called asmt_assessment_instance (Read) however this still does not unlock those fields on the survey for a user. Im super confused what SN wants from me here
Matt Todd
Ok i found a permission that makes it work. The role assessment_admin unlocks these fields. That works at least. What i noticed that assessment_read does not work because it is empty. Im not sure how to populate this role with the correct permissions
I have the same issue, but added the assessment_admin role to the user record did not correct the issue for me. What is odd is that I can see the fields when going directly to the case, but when dot-walked from instance.task it is blank.
What's even more bizarre is if I click on another field, use the arrow keys to select field and then click "enter", I can see the name with a "Security prevents writing to this field" error.
