Could I execute a scheduled job from flow designer
JLeong
Hi guys,
I have a flow designer that creates an incident when a specific transform map fails. But instead of creating an incident right away, I would like to re-process it or re-execute the scheduled job. Is there a way to call the UI Action or is there another way
Thanks in advance.
Regards.
Marcin20
Giga Guru
You can use the custom Flow Action with the Script Step.
In the Script Step the scheduled job can be invoked i.e. like in this thread:
UI Action button to run a Scheduled Job? - Developer Community - Question - ServiceNow Community
The Script Step is executed server-side, so the similar code as above can be directly placed there.
Best Regards,
Marcin
If my answer helped you in any way, please mark this answer as helpful and correct.
Thankyou for response but I have implemented that based on daily trigger condition.
