Flow Designer - Erro - Invalid pharmacy compound uuid: 4e536ea7-84ba-4819-bedb-344306fef337
Bruno Moreira
  has anyone experienced this error when activating a Flow in the Flow designer?
I can change and save my flow. I can test the flow, but I can't activate my flow.
I'm on the Washington DC version patch4-hotfix1
2 ACCEPTED SOLUTIONS
Bruno Moreira
I removed the "Get catalog variables" component and inserted it again and the problem was solved
Paul Sisson
*** UPDATE ***
There is a solution that has not been accepted as the "official solution" but it definitely is the best one.
The problem:
You have a data pill somewhere that is broken/corrupted/mapped incorrectly.
This is typically due to removing an input that was previously used or needed, but I'm sure it happens other ways.
The solution:
Go find the data pill that's corrupted and fix it. You might have to go through each input on each step to find it, and there might be more than one.
SHOUT OUT TO @JeevesS  for the solution. Go give him/her a thumbs up!
*** END UPDATE ***
I didn't have a "Get Catalog Variables" action to delete, so I just deleted everything and re-did it. Worked like a charm!
27 REPLIES 27
Just to re-emphasize or maybe clarify, I had to delete the entire Flow and recreate it..BUT..I just opened the Flow to be deleted on one tab and a new Flow on another and copied exactly what I did before. Works fine now.
JeevesS
This means you have a data pill in your flow is not mapped/broken/corrupt. Go via all the data pills and make sure they are mapped. Then re-publish it.
This is was much more helpful than the checked "solution".
^^^^^^^^ This answer was more helpful than official solution.
Bruno Moreira
terrieb
Can you test your flow? I found that the error was linked to my "Get Catalog Variables" in the test message. Try to do a test even with the unpublished flow and see what the error message is.
