Flow Designer Export
Mike_R
How can I move a flow between instances without an update set. Is there a way to export to xml and then import in another instance?
9 REPLIES 9
You wouldn't have to re-create it. You could just create an update set and add that flow specifically to it. It will then capture the flow and you can move it between instances.
Hi @Mike_R ,
I faced a similar situation where a flow wasn’t captured after moving it to another instance. During testing, I learned from my senior that flows aren’t automatically captured when moved outside an update set, so you’ll need to add them manually in the new instance.
I also found this related discussion: What is the procedure to move flow to another instance?
Please check it out.
Best Regards,
Anjal
It is helpful to me. Thank you Elijah.
not getting option to fetch xml.
can you let me know what to do
Brad Tilton
The flow has a number of different records on different tables that makes moving it outside of an update set or app scope difficult. If you've created it outside of an update set you do have a couple of options for getting it into an update set:
  1. Open a new update set and use the copy flow functionality to create an identical flow that will get captured by the udpate set.
  2. Use the Add to Update Set share utility to add the flow to an update set. (I'm pretty sure it has the capability, but I haven't used it in a while and it's not in the notes on the share site)
