‎04-09-2020 07:16 PM
Hello Flow Designers,
I am trying to automate a service catalog order. I created a service catalog trigger and three actions using flow designer. Everything went fine except for the second action: it created a catalog task for the requested item, however, the "Fields [Catalog Task'" field, which is a reference field, wasn't pulling the values from the ref table. It didn't allow me to drag data pills and it had no data pill picker button next to it.
Flow Designer
‎04-16-2020 09:31 AM
Hi Ankur,
Thanks for you reply. I managed to get it working after reloading the page. I guess it was either a client side bug or a browser issue.
‎04-13-2020 11:03 PM
Hi Mohamad,
So you are not able to select any field from sc_task to set the values?
Hi Ankur,
‎04-14-2020 06:44 AM
I am new to ServiceNow and have only done 1 flow but in that one I needed a task to GET CATALOG VARIABLES.
Is that what is needed here after the Service catalog step?
