Flow designer - SysID displaying for Location details instead of name
Winnie P
Hello Team,
I have a request which is created to check Locations that does not have a site support group assigned. I created a flow design to try and add the list of locations to the RITM, but the details appear as sysIDs - how can I display the list with the Name instead? ie:
Thank you.
Thank you Hitoshi. That worked ... for 1 Location record. I don't suppose you have a formula to make it work for more than 1 Location record, hence why I wanted to use "records" usually there's about 2 -3 location records a week that needs to be updated. Cheers.
I will actually post another question to figure out the multiple location records if found - as I have other queries to add, thank you.
If you want the same thing for multiple location records then you have to go with a scripted approach like this : -
Sourav
