For Each Item flow logic how to get the consolidated output
Jamsheer1
while creating a record I need to get related list of records and perform a REST action for each record . I'm using this flow and its working fine however I've no idea how we can get the final output to a variable.
Basically each REST response will return an unique reference and I wanted to update the concatenate value of response to a field in the table.
jamsheer
I tried this before and only got the value of the last element in the loop as a "concatenated value".
It seems like I would have to input the concatenated value from the previous loop as an input to the concatenation step. How do I get the output parameter the concatenation script as an input parameter so the values will be concatenated?
When I tried this before I was unable to use the 'sumoutput' in the Update Record step and I was only able to get the last iteration record.
Whats the content of your script to concatenate value action?
Hi Jamsheer,
I believe this is addressed in Quebec with the introduction of the flow variables, More details here - https://developer.servicenow.com/blog.do?p=/post/quebec-fd-whats-new/
You can store the values in flow variables without updating in records and use it finally.
  • Create a flow variable 'response'.
  • Add new step under rest inside for each loop to set the flow variables.
  • Select the flow variable created and use below script inside it,
    fd_data.flow_var.response += fd_data._2.1_REST_CALL + '&&&';
    return fd_data.flow_var.response;
    NOTE : fd_data._2.1_REST_CALL have to be checked with your flow and &&& is used as separator for multiple responses.
