Help to calculate the difference between two fields in minutes
Thrupthi
I have a two fields on my table which are of date/time type; I have start date and end date, inorder to calculate the difference i have created a new field of type duration
Business rule is been for this it returns a value in "days:hours:minutes"seconds"
Instead i just want the field to calculate the value in minutes; can someone please help me with this
Business rule:
if (current.u_incident_start_date.nil() || current.u_incident_end.nil()) {
current.setValue('u_incident_duration_calculation', '');
var st = new GlideDateTime();
st.setValue(current.getValue("u_incident_start_date"));
var ed = new GlideDateTime();
ed.setValue(current.getValue("u_incident_end"));
var dur = GlideDateTime.subtract(st, ed);
current.setValue("u_incident_duration_calculation", dur.getValue());
})(current, previous);
That could be the issue. If you donot want decimals , try the updated code
	var st = new GlideDateTime(current.u_incident_start_date);
	var ed = new GlideDateTime(current.u_incident_end);
	var sec = gs.dateDiff(st, ed, true);
	var minutes = sec/60;
	current.u_incident_duration_calculation = parseInt(minutes,10); // Remove decimals
15 REPLIES 15
Yes u_incident_start_date (This is the start field of date/time type)
u_incident_end (This is the end field of date/time type)
u_incident_duration_calculation (this is the field created to calculate the difference between start and end in minutes; and its of integer type)
Ok try this and let me know if you see any message at the top after you update the record
 var gd = gs.dateDiff(gr.getDisplayValue('u_incident_end'), gr.getDisplayValue('u_incident_start_date'), true); // gd will be in seconds
var min = gd/1440; //Do your calculation,
gs.addInfoMessage("Second printed:--->"+gd+"Minutes Printed:---->"+min);
current.u_incident_duration_calculation= min;
Please mark my response as correct and helpful if it helped solved your question.
-Thanks
Hi Prateek,
Nothing worked, it din't display any value
Just to inform you i have written a Before Business rule with update and insert checked and condition when end date changes.
can you try this for testing purposes. Make sure you are changing End Date
-Thanks
No Prateek nothing helped again
It displays blank
