Help with App Engine Pipeline configuration. Will not validate
tomhamill
I get the following error when trying to validate a pipeline in my new PDI.:
Could not connect to the environment. [Method failed: (/api/sn_pipeline/pipeline/validate_connection) with code: 401 - Invalid username/password combo]
Not sure where to look to validate the username/password combo.
Marc Mouries
Go to App Engine > Environments and check the credentials of each environment.
PS: Make sure you add the topic App Engine to your question
Hit the 👍 Helpfulor or Accept link ↓ if this answer brings you closer to achieving your goal
Sandeep Kumar13
Hi @Marc Mouries ,
As per your reply ,we have validated credentials of each existing environments in instance.
when we ae trying to validate, for one environment it's validating with User name and password.
but for other environment with same user name and password is not validating.
Attached screenshots for reference.
having the same issue
Marc Mouries
The screenshots did not come through. Can you repost?
