Help with notification
RudhraKAM
I have a requirement where we created a table XYZ and a record producer , when the record producer is submitted the record will be inserted in the the table XYZ , when ever a new record is inserted, we need to send a notification to a group ,
if user is  John  who submitted the record producer , we need to get john's email address and send message from that, not from default ServiceNow address. and cc the user too
and  If a record has an attachment, send the attachment along with the outbound message.
How do we achieve this ?
Thanks in advance
It worked for me. Here is the Code I tested:
(function runMailScript(/* GlideRecord */ current, /* TemplatePrinter */ template,
/* Optional EmailOutbound */ email, /* Optional GlideRecord */ email_action,
/* Optional GlideRecord */ event) {
email.setFrom(current.opened_by.name+" <"+current.opened_by.email+">");
printattachments();
function printattachments(){
var gr =new GlideRecord('sys_attachment');
gr.addQuery('table_sys_id',current.sys_id);
while(gr.next()){
template.print('Attachment: <a href="http://'+gs.getProperty("instance_name")+'.service-now.com/sys_attachment.do?sys_id='+ gr.sys_id+'">'+ gr.file_name+'</a>');}
})(current, template, email, email_action, event);
20 REPLIES 20
Sorry my bad we can't use gs inside email script. Use the below code, it should work:
where do i write this?
Write in same highlighted place (Line number 14 above) where you wrote before. Just override that line with this new line of code.
Also delete line 1-7 as those are written twice.
printattachments();
while(gr.next()){
