How can i switch to Servicenow Native UI from App engine studio?
aditi sharan1
I created a PDI and its redirecting me to app engine studio whenever i login, i want to work on the native ui , so how can i see that ?
I have the admin role too
Hi @aditi sharan ,
Your instance is using san diego release.
You just need to click on"ALL" on the left top corner of your screen and you will get your apps navigator , etc..
like below:
Kindly mark the answer as Correct & Helpful both such that others can get help.
Sandeep
Hi @aditi sharan ,
That's not App Engine Studio !!
 Its your native UI itself.
Sandeep
okay, but how can i switch to the normal view with application navigator, banner etc
Hi @aditi sharan ,
like below:
Sandeep
Pranay Lakhotia
The below steps helped me resolve this problem:
1. Click on your name on the top right.
2. Click on Change User Role.
3. Select Change User Role.
4. Save changes.
You should now be able to open the instance in the required view (native ui).
All the best!
Pranay.
This works for me, thanks.
I don't understand why this isn't more evident on the homepage, a lot of people must have problem by this
