How can I update a catalog variable in Flow Designer
Taha_Alawadhi
Giga Contributor
Hey guys,
I need your help!
I am trying to update a catalog variable in the middle of a workflow using flow designer
I don't see an OOB option to do that and when I tried this script as an action it didn't work. I am getting the variable value, but it won't change it
Thanks!
Taha_Alawadhi
Giga Contributor
I just found the solution
Way simpler than I thought
Jan K_lb_k
Hi Taha.
You could also create a reusable action, where you pass in the record, variable name and the new value. Then it can be used in other flows as well
  inputs.record.variables[inputs.variable] = inputs.value;
  inputs.record.update();
})(inputs, outputs);
Best regards, Jan
cms1
Can you share the entire new action ?
I am very new to creating a new action.
