How to add conditions in Flow designer
Nishant16
Need to delete records from sysrule_assignment table which is defined on certain conditions. Now i am using flow designer to trigger these deletions. How can i define the conditions defined in Assignment rules table to the flow so i can trigger the required deletion
i need to delete the below assignment rule from the sysrule_assignment table
I would instead have the catalog item use a reference variable that points to the sysrule_assignment table, and delete the record selected directly instead of querying on the conditions field.
