How to pass values from a from to a workflow that is inside another workflow
rocktheboat
Giga Contributor
How to pass values from a from to a workflow that is inside another workflow.
Thanks for your answer.
ashwinkumar_pat
Giga Expert
! !Hello Som,
Here is the documentation on how to do that.
1. Define inputs on the subflow - Define inputs for a subflow
2. Pass inputs from main workflow to subflow - Invoke a subflow in a workflow
Here is an example -
This example simply passes the value of short description field on incident form to a subflow. The subflow then copies the value of short description over to description field.
Step 1 - Create an input variable in subflow of type string and label it as short des
Step 2 - Add a run script to read the input variable in subflow
Step 3 - Drag and drop the subflow in main flow. You will get a dialog where you need to set the value of input variable you created in subflow in step 1.
Let me know if you need any additional info on this.
Thanks for letting me know, I was not seeing the button for the correct answer, as the windows were collapsed. I have done it now! Thanks Again.
Does it work for sc_req_item tables as well
