How to set value to reference field using sys_id
peshwen
Giga Contributor
Hi all,
I am having sys_id of company name and i want to set that company name to reference field using sys_id.So how to do it?Please anyone can tell?
25 REPLIES 25
Hi Mihir,
I tried but the value is not setting to field.Its empty only.
Thanks ,
Nikhil
Mihir Mohanta
Can you share the script that you have written ?
Mihir
function ajax(serverResponse) {
  var answer = serverResponse.responseXML.documentElement.getAttribute("answer");
    g_form.setValue('contractorCompanyName',answer);
script include function:
getCompanyDetails : function() {
  var answer = " ";
  var number = this.getParameter("sysparm_companyname");
  var index = number.indexOf("(");
  var index1 = number.indexOf(")");
  var s = number.substring(index+1,index1);
  var gr = new GlideRecord("core_company");
  gr.addQuery("name",s);
  while(gr.next())
  answer =   gr.getValue('sys_id');
  return answer;
This is code.I am getting correct sys value in answer variable.But it is not being set in contractor campany variable.It is reference variable.in variable s i am getting the company name.in var number i am having company name with some prefix which i dont need.
Nikhil
Hi Nikhil,
A couple of pointers that may be helpful:
a) have you tried setting the field within the callback function?
b) make sure your variable name contractorCompanyName is right.
c) make sure it's actually a reference field of the Company table
Berny
I'm almost sure a) will solve your problem
I hope this helps.
Berny
