How to set value to reference field using sys_id
peshwen
Giga Contributor
Hi all,
I am having sys_id of company name and i want to set that company name to reference field using sys_id.So how to do it?Please anyone can tell?
25 REPLIES 25
Tejas Tamboli
Giga Guru
Hello Peshwen,
If I understand correctly you want to set a reference field using a sys_id.
You should do it like below:
current.yourfieldname = sys_id of the record that you want to set.
Hope that helps.
Thanks and Regards,
Tejas
