I am facing "no readable comment field" issue in Portal form , can any please help me on this?
Arjun Kumar Le1
11 REPLIES 11
Can you try with OOB Ticket Page?
@lenkatukuna
Any update on this?
If your query is resolved, please mark the correct answer to close the thread.
Arjun Kumar Le1
I am not finding the post button below the comment field, is that any reason. Please help with this .
I think you got the answer for the above in this thread
https://community.servicenow.com/community?id=community_question&sys_id=12cf0283db65a0109e691ea6689619dd
Mohit Agrawal
Giga Contributor
The comments field of the table might not be selected to be visible on the regular activity stream in the desktop application.
Check the value of the system property glide.ui.<table>_activity.fields
Add the comments field to the list of fields in the system property if it is not there.
